Did a boost leak test and had no leaks except that it was leaking out of the dipstick hole. Is this normal? The dipstick is older, and the seals are probably gone, but regardless, should there be pressure coming out of there? This was around 5 psi and a considerable amount was coming out.
Boost leaking from oil dipstick hole! - fuzzymonkey14:54:43 07/18/11
